Old 07-06-2009, 03:31 AM   #1
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
^ It feels like aluminum foil that we use in the kitchen, but one side is sticky. That's why it's called aluminum tape.
I think I might have done a little overkill. On the back end, after wrapping with aluminum tape,
I had some Thermo-Tec Heat Shield left over and wrapped some more.
I think the Thermo-Tec can withstand the heat much better than the aluminum tape.
By the way, do you wrap that big bubble like thing in between the tube by the ECU? What is that for?
Old 07-06-2009, 12:26 PM   #2
PatrickJohnson
Drives: 2008 Yaris LB
If you read earlier in the thread, i think it's actually the original post, it says you don't have to cover that part, but that it does make a difference if you do. I don't have that part covered on my install, but only because I didn't have large enough material to do so, and i plan on doing it when i get back to the store.
PatrickJohnson is offline   Reply With Quote
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
