Old 07-06-2009, 02:55 PM   #1
jkuchta
Drives: 2007 Yaris hatch (red)
Originally Posted by suprf1y View Post
Well that pretty much makes it difficult, and unaffordable.
If I had to weld the cores, then grind them to maintain your stock lifter setup, that would make it too expensive.
Sorry guys.
I'm pretty sure the buckets aren't that expensive.
Wouldn't it be possible to offset grind the cams on their base circles and then use thicker buckets to take up the slack, thereby giving you more lift without running into coil bind?
jkuchta is offline   Reply With Quote
Old 07-06-2009, 04:05 PM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I don't think you want more lift. With VVTi you might end up hitting the piston.
You have four valves already. Wouldn't better intake and exhaust manifolds with porting give more reliable results?
Old 07-07-2009, 09:53 AM   #3
suprf1y
suprf1y's Avatar
Drives: 05 Echo
By all means, see what thicknesses are available, and price them out.
I'll keep an eye on the thread.
Like I said, if I think we can do something, I'm game.
Not sure what you mean by offset grinding the cores.
suprf1y is offline   Reply With Quote
Performance Camshafts acer1958 Performance Modifications 2 11-09-2012 06:09 AM
