Blackend inside exhaust tip
I was washing my car and noticed black stuff inside the exhaust pipe and outside on the bottom part, is this a problem or not? Picture of black stuff below hopefully you can tell.
http://www.midatlanticnostalgiaconvention.com |
SIPNDEW
normal. its just carbon buildup. wash it up real good and then it will be gone! until next time...muhahaha
Thanks guys, just needed to be sure.
![]() ![]() ![]() Drives: Yaris Join Date: May 2009
depending on your driving habits, people following you may see a puff of "smoke" come out of your exhaust, which is actually just that buildup making its way into our lovely green earth :D . but if you drive balls (errr... ovaries...??) to the wall all the time the buildup never.. builds.. up... in your exhaust :D
im almost ashamed to own a yaris after reading this
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
SIPNDEW
why?
don't worry, we're all ashamed you own a Yaris too
DARK PHASE OF THE MOON
Drives: 07 liftback Join Date: Apr 2009
Carbon, the time to worry is if it starts to turn light gray
Half a Bubble Off Plumb
Mine stays shiny and clean inside under normal circumstances. If I punch the gas pedal all the way down and hold it for a while, as I've occasionally done on a long uphill merge ramp onto the Interstate nearby with 4 adults in the car, the exhaust tip turns black inside. Get beyond about 80% load, and the engine goes into open loop operation with the mixture enriched. You'd likely see some smoke from the tailpipe under those conditions. Wipe out the inside of the tip with a damp paper towel, and see how long it takes to blacken again. Pay attention to how you're driving when it does.
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
But, How come most Fords have clean tail pipes?
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
because the Found On Road Dead does not run long enough for carbon buildup...
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
pretty pathetic isn't it. its a good thing im getting rid of it
#14 | |
![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jun 2009
LMAO!
LMAO!!!! |
ROFL!!!!!!!!!!!!!
![]() ![]() ![]() ![]() Drives: 2006 yaris Join Date: Oct 2008
| OEM Exhaust Tip Accessory | Split | Cosmetic Modifications (Exterior/Interior) | 36 | 07-12-2009 08:48 PM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
| exhaust tip | DJ_stone | Cosmetic Modifications (Exterior/Interior) | 1 | 01-20-2009 07:52 PM |
| Exhaust Tip Decision | ruimond | Performance Modifications | 19 | 12-15-2008 12:49 AM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
