Old 07-07-2009, 12:31 PM   #20
PatrickJohnson
Drives: 2008 Yaris LB
No. I installed an aftermarket 07-08 kit on my 09.
I purchased the 09 OEM fog light trim pieces from my local dealer and the OEM fuse panel relay from an Ebay vendor. By purchasing the relay I was able to wire it using the factory wires that go from the under hood fuse panel, through the under dash fuse panel, to the headlight stalk connector (this is the same for 07-09). I didn't like the quality of the switch that came with my kit and didn't want to spend the money for a headlight stalk with the fog switch, so I used a different toggle switch.
do you happen to have part numbers on the oem trim and a specific seller on ebay for the relay? I think this will be my next mod.
PatrickJohnson is offline   Reply With Quote
Fog lights and shift knobs flip_yaris Cosmetic Modifications (Exterior/Interior) 4 09-26-2006 10:48 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-02-2006 11:38 PM
