Old 07-07-2009, 01:13 PM   #1
POORSHA
POORSHA's Avatar
Drives: 2008 LB
Is there a work around for the stalk using a dash mount switch. just like the $ 10.00 cruise?
POORSHA is offline   Reply With Quote
Old 07-07-2009, 01:23 PM   #2
Hmmmm... Actually, the circuit for the intermittent front wipers is built into the stalk, so a work-around is definitely possible, but would require a circuit like my rear intermittent one. Then, you would have a dash or column mounted knob to adjust the delay. It wouldn't require a switch, as the standard stalk has an intermittent mode.
variable intermittent wipers thebarber Cosmetic Modifications (Exterior/Interior) 27 10-18-2022 03:26 PM
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 10:39 AM
Making Intermittent Rear Wipers ttufrosty Cosmetic Modifications (Exterior/Interior) 1 08-12-2007 10:57 PM
