Old 07-08-2009, 06:51 PM   #1
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
n00b why dont you either leave or properly introduce yourself in the welcome forum. do you even drive a yaris? your just starting crap we dont need. all of your posts have been in this 1 thread. im sure they have a forum out there that discusses stuff you have found on google and wikipedia...
Old 07-08-2009, 07:16 PM   #2
Henry G.
Drives: 2008 Yaris HB
Good post and diagram PK.
I just decided with that roll of tape there I would finish the job and wrap everything on the big line (notice I'm staying out of the technical argument by not naming it):
Wrapped the "can" portion of the line by taking two pieces of equal length insulation and doing the zip tie/tape thing.
Did the piece of line that runs against the inner fender, kind of a pain. I found the trick was to cut the piece to the right length, take it back off, install 2 already looped(just barely so as to leave the maximum room) on the pipe, put the insulation back on then wiggle the zip tie loops over either ends and then tighten them.
After that section this one was easy, I used tape again even though I dont think heat is a concern way up front but because I figure the engine bay heat in general is likely to harden the zip ties quickly making them brittle and breaking them, so the tape was more of a securing thing.
And this pic is from under the car, this section of pipe is easier to do most of the work from under the car believe it or not. Same thing zip tie and tape.
Henry G. is offline   Reply With Quote
Old 07-08-2009, 10:01 PM   #3
EasyDriver
Drives: 2008 Yaris Meteorite LB
How you ever managed to get zip ties in the area near the alternator (picture 2) is beyond me! I tried and tried to do that, but couldn't get it done. Or, maybe my patience just ran out!
EasyDriver is offline   Reply With Quote
Old 07-09-2009, 10:30 AM   #4
texkid
The one with cheese on it
Drives: '10 Corolla S
Patience and a needle nose pliers to use as my second fingers. But mainly patience.
DIY: A/C Insulation
texkid is offline   Reply With Quote
Old 07-08-2009, 07:35 PM   #5
n00b
Drives: Car
To answer your's and PK198105's question of driving a Yaris, I do not. I drive an Echo (which has crappier a/c than the Yaris).
I don't feel like posting in the welcome forum. I've never done that on any of the forums I am a member of.
n00b is offline   Reply With Quote
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
