Old 07-08-2009, 08:11 PM   #1
b_hickman11
Drives: 08 Sedan
Does anyone know the longterm effects this mod will have on the AC components? This sounds like a good mod for the time being but will this cause the dryer or the Evap or other parts to go out at a faster rate? Sounds like this mod will create more water in the air which will cause the parts to work harder. Maybe even causing an increase in mildew build up which is already an issue with the stock system.
b_hickman11 is offline   Reply With Quote
Old 07-08-2009, 08:36 PM   #2
n00b
Drives: Car
There are no long-term effects other than a better working a/c.
n00b is offline   Reply With Quote
Old 07-08-2009, 11:01 PM   #3
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
evap core freezing up......
mikenacarato is offline   Reply With Quote
Old 07-09-2009, 12:41 AM   #4
mikenacarato
SIPNDEW
Drives: 15 STI
that would be the case if we insulate the HIGH PRESSURE line.
the compressor might not have to work so hard, neither your fan so i would say that long term effects would be beneficial.
ah, well then ill take your work on it. i have some heat shielding tape im going to use i just wanted to make sure the core wouldnt freeze.
Old 07-09-2009, 08:47 AM   #5
EasyDriver
Drives: 2008 Yaris Meteorite LB
evap core....
If anyone is concerned about the core freezing up....simply don't cover the entire line. It won't be as cold in the cabin, but you don't have to worry about it. If you covered the entire line, like I did, all you have to do is remove some of the insulation and the problem is solved.
EasyDriver is offline   Reply With Quote
Old 07-08-2009, 11:52 PM   #6
n00b
Drives: Car
wikipedia told you this?
Thanks, I'm done with this forum. I'll let you believe 2+2=5.
Old 07-09-2009, 03:06 PM   #7
b_hickman11
Drives: 08 Sedan
How many years have you had this mod?
Old 07-10-2009, 08:15 AM   #8
MadMax
MadMax's Avatar
That's the rub, no one has had this done on their cars for more than a couple of weeks; so if there are any adverse long-term effects, no one knows!
I might be crazy, but I simply never run the a/c in my Yaris even with the triple-digit temps we've been having for the past month or so. I also drive an open Jeep, so maybe I am used to it, or I've killed all the brain cells that would've told me I am nuts; but since I most drive on freeways without a lot of stops on my commute, the two windows down method keeps me comfortable enough...and it sure feels great when I walk into the air conditioned house!
Cheers! M2
Old 07-10-2009, 12:38 PM   #9
b_hickman11
Drives: 08 Sedan
Cheers! M2
I already knew the answer to the question. I was just trying to figure out how he knew that there were NO longterm effects.....
Old 07-12-2009, 02:05 PM   #10
Henry G.
Drives: 2008 Yaris HB
Drove into town yesterday, around 100 degrees the AC is definitely colder. So I call this one a success. If the AC breaks for some reason in the future (I doubt it) I will take 5 minutes and cut the stuff off before taking it to the dealer so they don't have a (weak) reason to refuse the warranty claim.
Henry G. is offline   Reply With Quote
Old 07-12-2009, 05:58 PM   #11
b_hickman11
Drives: 08 Sedan
You have the basic warranty or extended?
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
