Old 07-09-2009, 10:32 AM   #1
SailDesign
Drives: .
I have been doing some reverse engineering on the TPWS ECU, and have a solution (not yet implemented) to the multiple sets of wheels, choosing to run at higher pressure, using different sized rims, etc. issues.
You mention higher pressures a couple of times here. Is there something the TPMS system does with that? I'm running a bit high, and no trouble with the TPMS light.
Old 07-09-2009, 10:50 AM   #2
The system does detect both high and low. I just checked the service manual for the high limit, and I don't any hypermilers are going to get close to it: 87psi
Old 07-09-2009, 11:37 AM   #3
SailDesign
Drives: .
I think i'm safe, then.
Old 07-09-2009, 02:17 PM   #4
gammaray
gammaray's Avatar
Drives: 09 3D Liftback
Similar to what was stated above....my dealership charges $85 for the transfer, and a local tire establishment said they would charge $40.
gammaray is offline   Reply With Quote
Tags
tpms
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
TPMS Gauges - do they exist? Sodium Duck DIY / Maintenance / Service 24 03-01-2009 12:18 AM
15" TPMS friendly wheels for my '08. Ideas? auxmike Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 12-08-2008 08:01 PM
TPMS TinyGiant Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-22-2008 03:57 PM
