Old 07-10-2009, 04:59 PM   #1
PatrickJohnson
Drives: 2008 Yaris LB
Originally Posted by ecnal View Post
So, I've poured through 80% of these pages. I have an 09 Sedan, automatic, base model. No power windows or locks. No cruise either.
I would be looking to add a stalk for the cruise, from what I've gathered all I should have to do is get the stalk and hook it up? Does anyone have pictures of adding a stalk to an 09 automatic?
All you have to do on the '09 is add the stalk as the ECU is already wired for cruise. All that is required for the oem cruise is to buy the trim piece for your steering column that has the stalk hole and buy the stalk. then remove the steering column cover, plug in the stalk, and put the new cover on. If you don't want to foot the bill for new pieces, you can remove the cover and splice in switches to the factory wires as shown earlier in the this thread and in the diy.
PatrickJohnson is offline   Reply With Quote
Old 07-11-2009, 07:06 AM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I dont know about the 08's or 09's, but on my 07 the steering column cover already had a notched spot so you could easily cut out the hole for the stalk.
Old 07-14-2009, 01:53 PM   #3
Brentorius
Drives: 07 Mazda MX5 Copper Red
Smile
Good read!
Any updates on an 09 yaris MT? Any confirmations regarding the connector for the clutch switch?
Parts needed:
Clutch Switch: 88280-14030
Steering Cover: 4518452130b0
Stalk: 84632-34011
I already ordered the stalk on ebay for $29.99 shipped.
-Brent
Last edited by Brentorius; 07-27-2009 at 01:03 PM. Reason: Corrected part # Steering cover
Brentorius is offline   Reply With Quote
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
