Old 07-10-2009, 06:28 PM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
30: common to battery 12V
87: common to "stereo power wire"
85: common to "starter solenoid 12V"
86: common to GROUND.
87a: not used
so, only when the starter solenoid is engaged, the relay is in operation. because you're using 87 (NO contact) you won't be powering anything when the key is turned off. and because you've hooked 30 to "constant" your ACC circuit will be backfed power directly from the battery during the "start" cycle. since the ACC circuit does not power high-draw items such as the windows or AC or fan or defrosters, you should not have an issue with battery draw during the "start" cycle.
sound good?
also, this can all be done right at the radio (no need to run a feed from the battery itself)
Ahh - now we're getting somewhere. Thanks! That sounds like a solid idea.
Though it can all be done "at the radio" where would I tap into the "starter solenoid 12V" line? From the engine compartment, I presume?
- Brian
Share the Road
Old 07-10-2009, 06:31 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
i don't know the actual yaris wiring diagram so i won't say what i think is the obvious answer (at the ignition itself). for all i know the yaris uses sinking switches instead of sourcing to send the "start" signal.
Old 07-10-2009, 11:29 PM   #3
How about just eliminating the ACC cut relay and jumping the output contact terminals? The service manual says that its purpose is just to keep the clock and meter from flickering during cranking.
You could use a jumper wire with male spade terminals. Jump 3 to 4.
Old 07-11-2009, 12:49 AM   #4
BailOut
BailOut's Avatar
That sounded like a great and simple idea but it did not work. I jumped 3 to 4 to no effect. The interesting thing is that the clock works just fine (no flickering) with or without the ACC cut relay or 3-4 jumper in place.
Thanks for trying, though. Tomorrow afternoon I'll try wiring in a relay.
- Brian
Share the Road
Old 07-11-2009, 07:32 AM   #5
Try 3 to 5 then. I wasn't sure if the NO or NC contacts were being used.
Old 07-11-2009, 10:01 AM   #6
BailOut
BailOut's Avatar
I thought of the same based on the diagram you attached but pin 5 isn't used in the ACC cut relay's socket. It's an empty space.
- Brian
Share the Road
Old 07-11-2009, 11:32 AM   #7
OK. That makes sense - The EWD shows 3-4 being the contacts.
If you put a voltmeter on the power wire, do you actually see it still cut out with the jumper in place (or just sag to below 12V)?
Looking at the EWD, with that jumped, power should definitely still be applied to ACC during cranking.
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
Indicator relay removal Yariscoyne DIY / Maintenance / Service 9 01-07-2011 03:42 PM
Horn Relay? MGargano DIY / Maintenance / Service 7 11-14-2009 06:01 PM
DRL Relay andru47 Willing to Buy by private party 1 01-06-2009 05:47 PM
F/S Micro Relay for foglights. 1NZYaris1 Items for Sale by private party 7 12-29-2008 09:32 AM
