![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
My 3% might be high? The % of DYIs can't be that much by comparision, and most probably don't get a K&N, probably get a Fram, Wix, etc...
#2 | |
![]() ![]() ![]() Drives: Big Yellow Join Date: May 2009
Wix is kind of on the pricey side aren't they? I wouldn't know as they're not even sold at the el cheapo stores by me. I actually prefer Fram for oil filters because of the grip anyway even though I'm told Wix is the best there :) I do it myself because I want it done right, but I don't want it to be an expensive pain in the ass either. I ran K&N on my TJ for years and I never had any troubles with it, though I rarely cleaned the intake/throttle body. The worst build up of oil was honestly from the PCV. I actually had to get a pick tool to clean that out (not a valve on the TJ). Funny story, it's was the same with the Harley too actually. It used to have one of those doofy hyperchargers on it. The rubber fittings on the PCV just fit too loose causing oil to spit out (before I replaced the top end gaskets and rotated the rings correctly). I think I really want to put one of those PCV filters on the Yaris as described in the DIY section here before I start oiling my filters with engine oil:) I wonder if that would give the dealer an excuse to void the warranty. |
#3 | |
And the PCV issue really shouldn't be a big concern...most vents are at the bottom of the airbox, below the air filter, so you'd have to discard the air filter completely, or damage the gasket bad enough to allow it to effect the MAF...or the PCV vents downstream of the MAF near the throttle body. |
| Motor Oil and filters | Lafiro | DIY / Maintenance / Service | 94 | 03-15-2010 03:40 PM |
| K&N SRI- any experiences? | jonismyname | Performance Modifications | 22 | 05-29-2009 10:56 PM |
| TRD High Flow Oil Filters | Jansen | DIY / Maintenance / Service | 20 | 05-25-2009 04:36 PM |
| Drop in performance air filters which is best? | YarisSedan | Performance Modifications | 14 | 11-07-2008 09:52 PM |
| K&N intakes...bad? | SLIK4 | Performance Modifications | 21 | 06-19-2007 09:42 PM |
