Old 07-11-2009, 07:32 AM   #1
That sounded like a great and simple idea but it did not work. I jumped 3 to 4 to no effect. The interesting thing is that the clock works just fine (no flickering) with or without the ACC cut relay or 3-4 jumper in place.
Thanks for trying, though. Tomorrow afternoon I'll try wiring in a relay.
Try 3 to 5 then. I wasn't sure if the NO or NC contacts were being used.
Old 07-11-2009, 10:01 AM   #2
BailOut
Steals terrorist's lunch
BailOut's Avatar
I thought of the same based on the diagram you attached but pin 5 isn't used in the ACC cut relay's socket. It's an empty space.
- Brian
Share the Road
Old 07-11-2009, 11:32 AM   #3
OK. That makes sense - The EWD shows 3-4 being the contacts.
If you put a voltmeter on the power wire, do you actually see it still cut out with the jumper in place (or just sag to below 12V)?
Looking at the EWD, with that jumped, power should definitely still be applied to ACC during cranking.
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
Indicator relay removal Yariscoyne DIY / Maintenance / Service 9 01-07-2011 03:42 PM
Horn Relay? MGargano DIY / Maintenance / Service 7 11-14-2009 06:01 PM
DRL Relay andru47 Willing to Buy by private party 1 01-06-2009 05:47 PM
F/S Micro Relay for foglights. 1NZYaris1 Items for Sale by private party 7 12-29-2008 09:32 AM
