l33t3st Asshole
Drives: MY07 Yaris Liftback Join Date: Nov 2006
I think you'd notice.
wheel/tire weights are really important, with all the options out there you really shouldn't go heavier unless you're going significantly wider for autox/track purposes. although if you're going to a significantly larger wheel (17/18) and wider 7" 7.5" then adding weight is going to happen unless you get expensive wheels, so it's part of the territory. you will notice an extra 4lbs per corner, if not in acceleration then in braking or cornering. |
| stock wheel weight? | whiteghetto | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 02-06-2009 09:00 PM |
| Stock vs 123 Wheel HP (All-Motor) Dyno Graph | richardholdener | Performance Modifications | 47 | 12-13-2008 10:13 PM |
| Stock Wheel Covers? | barryware | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 11-04-2008 11:03 AM |
| stock wheel | wushumasterku | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 08-24-2007 12:52 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 09:30 PM |
