wow, these really works guys? ive got to try these on my car now. i wonder if my 08 liftback S got the cruise control lights in the instrument cluster? will soon find out.
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
![]() ![]() Drives: 2009 Yaris 4dr Sedan Join Date: Mar 2009
Can I assume that this will work for the 09 Sedan also?
What dangers/issues do I need to be worried about doing this mod? I have wires running all over from the LED mods so I am not worried about the work, just warranty issues. Blue |
Just an FYI, the burden of proof is on the warranty provider to prove that any modification resulted in a failure of the component or part being warrantied. They can't deny a warrantly claim unless they can prove your modification caused whatever is broken.
Well, my base model sedan is different
I guess I am screwed on this fantastic inexpensive mod.
![]() Here are the pics I just took of my steering column. As you can see, the brown and blue cables are missing.....so I think anyway. Can someone confirm? Circled the connector where I think the two additional cables should be: ![]() Picture from the bottom of the steering column... ![]() Blue |
#6 | |
That is correct. Looks like the 09 sedan doesn't have the wiring in place from the steering column to the ECM. Does it have the cruise indicators on the combination meter? You're not totally dead in the water for this mod. You just have to do the 07-08 method, which involves running a single wire from the switches to the ECM. Take a look at the tail end of this thread: http://www.yarisworld.com/forums/sho...cruise+control |
#7 | |
I will look at the 07-08 section. Thanks for the input. <-goes and mopes and grumbles about not having cruise control.
![]() Drives: toyota yaris 06 1.3 Join Date: Sep 2019
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
| SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 06:30 PM |
| steering wheel setup | aucorium | Cosmetic Modifications (Exterior/Interior) | 0 | 07-24-2007 01:05 AM |
| How do you take off steering wheel | mrrock | Cosmetic Modifications (Exterior/Interior) | 3 | 12-05-2006 10:16 AM |
