![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2009
no fixes on this? Ive cleaned out my hose twice this year. im thinking of getting a new hose from homedepot...
its an easy job to unclog the hose, but its annoying that i have to do this.... |
#2 | |
If you look at the picture below, without the filter in place, anything that enters the outside intake has a direct path into the air box. With the filter there, you will prevent particulate from getting into the box, where it then plugs the drain and provides a breeding ground for molds. Even if you haven't had the drain fully plugged, the stuff that enters without the filter will stick to the walls of the box. So, if you've run without the filter for any period of time, before adding the filter it would make sense to disinfect the airbox as well as you can with something like Ozium or Lysol. AC Box.jpg |
#3 | |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
CTScott you are always quick with the trouble-shooting and diagrams! Someone should give you an MVP (most valuable poster) award! Thanks, R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it." -The Fitful One
#4 | |
Still living with this distgusting smell, cant use the AC half the time. |
#5 | |
Here's where it is (top left side of the passenger footwell): AC hose.jpg Here's what it looks like when you pull it out of the flloor: AC Hose 1.jpg |
#6 | |
I love the back of my car, the front... not so much |
For RHD cars it is the same but on the opposite side of the center console.
| Air Conditioner Noise & Leak? | Dawn Eshelman | DIY / Maintenance / Service | 116 | 07-21-2015 01:22 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
