Old 07-13-2009, 11:21 AM   #1
Originally Posted by nisyota View Post
no fixes on this? Ive cleaned out my hose twice this year. im thinking of getting a new hose from homedepot...
its an easy job to unclog the hose, but its annoying that i have to do this....
After looking at the AC section of the service manual, I am mighty glad that I put the filter in within the first week that I bought the car.
If you look at the picture below, without the filter in place, anything that enters the outside intake has a direct path into the air box. With the filter there, you will prevent particulate from getting into the box, where it then plugs the drain and provides a breeding ground for molds. Even if you haven't had the drain fully plugged, the stuff that enters without the filter will stick to the walls of the box. So, if you've run without the filter for any period of time, before adding the filter it would make sense to disinfect the airbox as well as you can with something like Ozium or Lysol.
Old 07-13-2009, 12:46 PM   #2
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Thumbs up
Attachment 25907
Yet another great reason to check and make sure one's Yaris is sporting a cabin filter (most aren't)! Glad I caught mine early on too.
CTScott you are always quick with the trouble-shooting and diagrams! Someone should give you an MVP (most valuable poster) award!
Thanks,
R2
-The Fitful One
Old 07-18-2009, 06:40 PM   #3
Lafiro
Drives: 06 Yaris Sedan
Attachment 25907
Thanks! But I still cant find where the hose is under the car.
Still living with this distgusting smell, cant use the AC half the time.
Old 07-19-2009, 10:07 PM   #4
It can be hard to find from under. You can easily access it from about. Just have a pan or bucket under the hose as you clear it, so you don't get the output all over the carpet.
Here's where it is (top left side of the passenger footwell):
Here's what it looks like when you pull it out of the flloor:
Old 10-03-2014, 12:33 AM   #5
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
Attachment 26199
Attachment 26200
Is this the same for a right hand drive sedan?
I love the back of my car, the front... not so much
nobodywise is offline   Reply With Quote
Old 10-03-2014, 06:37 AM   #6
For RHD cars it is the same but on the opposite side of the center console.
Old 10-03-2014, 08:59 AM   #7
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
So you mean it would be on the right side of the car and run to the top right of the carpet orrrrr?
I sent you a private message
Air Conditioner Noise & Leak? Dawn Eshelman DIY / Maintenance / Service 116 07-21-2015 01:22 PM
