Old 07-13-2009, 11:37 AM   #1
toast
Drives: 2007 LB
The "problem" with the self adjusting rear drum brake is they only work when you back up and it takes some force to make the adjusters work. If you really think about it, how much do you back up? If you just back up 3 feet and gently touch the brakes it's just not going to work. When my rear drums start making a little squeaking I just make sure that I roll back a little further out of my parking spot and hit the brake sharply a couple of days and it goes away for a while. If that doesn't do it, then I start taking things apart.
toast is offline   Reply With Quote
Old 07-13-2009, 01:08 PM   #2
RedRide
RedRide's Avatar
This is true that you need to "hit the barake sharply" for the self adjusters to work properly.
I also develped the same habit years ago (with the cars that had rear drums) to ocasionally hit the brake a bit harder when backing up.
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
