![]() ![]() Drives: 2009 Yaris 4dr Sedan Join Date: Mar 2009
Well, my base model sedan is different
I guess I am screwed on this fantastic inexpensive mod.
![]() Here are the pics I just took of my steering column. As you can see, the brown and blue cables are missing.....so I think anyway. Can someone confirm? Circled the connector where I think the two additional cables should be: ![]() Picture from the bottom of the steering column... ![]() Blue |
#2 | |
That is correct. Looks like the 09 sedan doesn't have the wiring in place from the steering column to the ECM. Does it have the cruise indicators on the combination meter? You're not totally dead in the water for this mod. You just have to do the 07-08 method, which involves running a single wire from the switches to the ECM. Take a look at the tail end of this thread: http://www.yarisworld.com/forums/sho...cruise+control |
#3 | |
I will look at the 07-08 section. Thanks for the input. <-goes and mopes and grumbles about not having cruise control.
ctscott,
one last question (for the next 30 seconds )With the 07=08 mod, all we are doing to shorting pin 40 on the ECU to ground to turn on the CS and then short it to ground with a load (~600 ohms) to set the CS.. Or did I miss something? Blue |
That's all that's to it. See if your sedan has a wire already in pin 40. If so, you can tap it way up under the dash (per the discussion buried in that thread), or at least tap it somewhere along the line.
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
if you are standing in front of the car looking at the engine bay, it is attached to the firewall in the upper left corner
![]() Drives: Yaris Join Date: Jul 2009
I installed the CC, when I switch it on the speedometer jumps once , pressing the set buttom dosen't set the speed . While installing , by mistake I connected the 12 V supply instead of the ground which stalled the engine immediately . Can anyone help me if I have screwed up the CC function of my ECU. The car is running fine otherwise.
#9 | |
I would say that there is a good chance that that ECM doesn't have cruise control, as that part number is not a USDM/CAN one and so far it appears that just ECMs for those markets have the functionality. One test that you can try is to measure the voltage on pin 40 of the ECM connector A21, with the connector in and the ignition in the ON position. If you measure +12VDC to ground on that pin, then there is a good chance that your ECM supports cruise. If you measure 0 VDC to ground, then it definitely does not.
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
| SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 06:30 PM |
| steering wheel setup | aucorium | Cosmetic Modifications (Exterior/Interior) | 0 | 07-24-2007 01:05 AM |
| How do you take off steering wheel | mrrock | Cosmetic Modifications (Exterior/Interior) | 3 | 12-05-2006 10:16 AM |
