Old 07-13-2009, 09:25 PM   #1
Originally Posted by Blue_dragon_192 View Post
ctscott,
one last question (for the next 30 seconds )
With the 07=08 mod, all we are doing to shorting pin 40 on the ECU to ground to turn on the CS and then short it to ground with a load (~600 ohms) to set the CS..
Or did I miss something?
Blue
That's all that's to it. See if your sedan has a wire already in pin 40. If so, you can tap it way up under the dash (per the discussion buried in that thread), or at least tap it somewhere along the line.
Old 07-13-2009, 09:35 PM   #2
Blue_dragon_192
Drives: 2009 Yaris 4dr Sedan
Ok. The next dumb question. Where is the ECM??????
Blue_dragon_192 is offline   Reply With Quote
Old 07-13-2009, 09:42 PM   #3
PatrickJohnson
Drives: 2008 Yaris LB
if you are standing in front of the car looking at the engine bay, it is attached to the firewall in the upper left corner
PatrickJohnson is offline   Reply With Quote
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
