Old 07-14-2009, 10:50 PM   #1
silver_echo
ekodrvr
silver_echo's Avatar
how many miles on the car? when does this happen? car hot? cold? beginning of when you try? later on?
i like this smiley...
silver_echo is offline   Reply With Quote
Old 07-14-2009, 10:56 PM   #2
advocate
Drives: car
27,000. It happens after very hard acceleration in 1st when shifting to 2nd. It doesn't happen in any other gear. Car is relatively hot from outside temp but not operation. After it happens I usually don't try to push 1st again. It's happened 2 or 3 times now total over a year or so. I've always assumed that the car just couldn't handle it with stock equipment.
Old 07-14-2009, 11:06 PM   #3
silver_echo
ekodrvr
couple things to try... replace the trans fluid, then check and make sure that your clutch line is not flexing out... speaking of which, hey garm, is there a braided clutch line available?
New Owner - Lights on Gear Shift javagirl New YARIS Purchase Forum 8 05-22-2009 03:23 AM
Reverse gear crunch Frankd1 DIY / Maintenance / Service 5 04-13-2009 01:43 PM
Yaris 2007- How to Restart Multimode gear? ronen DIY / Maintenance / Service 1 02-21-2009 06:09 PM
Sticky When Shifting and Sticky When Reving? jouslee DIY / Maintenance / Service 22 01-24-2007 12:07 AM
clicking into first gear tekmoe General Yaris / Vitz Discussion 9 11-01-2006 03:44 AM
