Old 07-18-2009, 09:56 PM   #1
better mileage w/ skinner tires
normally our chevy aveo has 185-60-14's. i recently "upgraded" to 14" aluminum wheels w/ 175-65-14 tires....
w/ 185's the aveo typically would get about 7L/100km hwy in the summer....this last tank of mostly highway w/ some stop and go on it was 6.17L/100km. i usually do 120-130km/h on the highway (about 100 on hwy 6)
i was pleasently surprised -- i didnt think it would make that huge of a difference...
Old 07-18-2009, 09:59 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
not bad, did you factor in the 1% difference in height as well? since you went with a smaller overall circumference, you need to "remove" 1% from your mileage number (it's slightly more than 1% but whatever lol)
Old 07-18-2009, 10:41 PM   #3
EasyDriver
Drives: 2008 Yaris Meteorite LB
skinnier tires....
Check out this tire info.....http://www.miata.net/garage/tirecalc.html
EasyDriver is offline   Reply With Quote
Old 07-18-2009, 11:41 PM   #4
MadMax
MadMax's Avatar
Makes sense, less rolling resistance. I know I get lower gas mileage from Sprocket due to its taller, wider tires.
By the way, unless the dealer (who installed the wheels) adjusted it somehow, my Yaris' speedo is spot on with the larger wheels; according to my GPS.
Old 07-19-2009, 09:22 AM   #5
well, even w/ the 1% difference in height, im still using about 0.75L/100km less
Old 07-20-2009, 10:39 AM   #6
Cosworth
Drives: S sedan
what is the difference in weight of the tires?
Is one tire more stickier than the other (i.e. wear rating and traction rating)?
Cosworth is offline   Reply With Quote
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 07:40 PM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 10:44 AM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 07:58 PM
Selling winter tires and low profile floor jack with 2 stands voodoo22 Canada 10 11-16-2009 10:12 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 02:23 AM
