Old 07-20-2009, 05:13 PM   #1
Vince87
Drives: 2007 2DR Yaris
I do have a multimeter, and get a 630 ohm reading when I check the resistance at both ends of the resistors with both switches pressed.
The switches must be N.O. because if I dont press on both I dont get any reading. It's the 1st time I'm using a multimeter how can I verify the continuity of my switches??? thanks again
Vince87 is offline   Reply With Quote
Old 07-20-2009, 05:24 PM   #2
With the switches you should see a high value or OL when they are not pressed and 0 ohms when they are. Or, in circuit 0 when on/off is pressed an 630 ohms when set is pressed.
Old 07-20-2009, 05:52 PM   #3
Vince87
My friend, you might have found my problem !
- When on/off is pressed i get a 530 ohms reading
- When set is pressed, i get 624 ohms
I have no idea why I get this 530 ohms reading... I might make another set of switches since I have 2 other swithes a lot of resistors...
Old 07-21-2009, 01:44 AM   #4
Revsson
When in the Ohm setting, did you touch the two probes together and
get 0 Ohms? Just checking to see that the meter is calibrated, which
could throw off your readings.
Old 07-21-2009, 07:46 PM   #5
Vince87
Yes I did, my multimeter is brand new so its probably well calibrated...
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
