Old 07-21-2009, 08:50 AM   #1
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Thanks for the update-I was just wondering how many miles you were up too a couple of days ago.
As far as the "pinging" problem you're having if your check engine light is not on I would start with a couple healthy doses of (reputable) fuel injector cleaner (such as Chevron Techron). Just be sure to "schedule" both doses for right before an oil change (I would run both doses back to back in your case).
Also if you have access to Shell brand gas I would try to use that exclusively or at least as often as possible. Shell has a well respected additive package.
I think I remember reading that you track your fuel mileage-any drop in fuel economy?
Thanks,
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 07-21-2009, 10:26 AM   #2
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
Thanks,
R2
I actually added a Gumout fuel system additive yesterday and filled up with Chevron fuel. So far, no pinging. The pinging was actually intermittent. But, I think the additive took care of it so far.
As far as my gas mileage. Yes, I have seen a decrease in it. I only get 36mpg with my a/c on. I use to get 44mpg when I now got the car, even with intake, exhaust and headers.
thanx!
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 07-21-2009, 03:24 PM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
thanx!
new sparkplugs, seafoam the bitch and then do an oilchange. Clean that intake manifold right out. Do a can in the intake line... and one in the gas tank.
if there is a problem with carbon/gunk.. that'll fix it up. Seafoam is only like $8 a can.
Old 07-21-2009, 06:30 PM   #4
trini_per4mance
New plugs, intake cleaner, and mass air sensor cleaner will be done this Saturday. I'm afraid to use any of those gunk cleaners.
thanx!
Old 07-22-2009, 11:55 AM   #5
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
thanx!
seafoam i believe is pure petroleum.... not weird stuff like acetone...
But, the tuen-up you have scheduled should help out I'd think... Good luck... looking forward to your next post when you hit 400k.
Old 07-22-2009, 02:24 PM   #6
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Here's Seafoam's MSDS: http://www.montanajacks.com/msds/seafoam-msds.pdf
It contains "pale oil," naphtha and isopropyl alcohol.
It's your decision whether isopropyl alcohol is "weird stuff like acetone" or not.
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
