Old 07-21-2009, 12:51 PM   #1
MadMax
MadMax's Avatar
Originally Posted by talnlnky View Post
I got some large size heater core tubing (that rubber stuff that connects your radiator to your motor. Going to wrap the AC pipe with foam, then cover the foam with this rubber tubing. Its oil/fluid resistant, and also hi-temp. Should work well, and the dull black color should make it look fairly stock/stealth.
Take pics and post 'em!
Cheers! M2
Old 07-21-2009, 02:24 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Cheers! M2
will do... might not be till next week... I got soccer tonight so I probably wont pick up the foam until tomorrow... and then to make sure it looks nice I want to take my time... so my work will most likely be slow.
I'll be cutting a slit down the tube (think split loom) and then either zip tie it closed... or better yet... maybe silicone sealant.
Old 07-23-2009, 11:51 AM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
ok... started working on this... The rubber heater core tube fits perfectly over the pipe.... except when the pipe bends. Going to stop by home depot or lowes on the way back to see if I can find a thin type of foam to cover the pipe. There are a few corners which which are too tight for me to get the hose to bend around, so I'll have to cut weird wedges to cover the corners. Then i'll just have to wrap black electric tape neatly around that to make it stay in place well. Even if I don't find anyfoam... I'm sure the rubber heater core tubing will insulate it fairly well. Will post pics when i'm done.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
