Old 10-08-2010, 10:33 AM   #1
jeff618
jeff618's Avatar
Drives: Mazda 3
Thumbs up 14" & Wiper Rebate Info
Originally Posted by dragoneyes View Post
Instead of using 26" drivers and 14" passenger, can I use 24" and 16". That is substracting 2 and adding 2. and this will avoid them hitting over each other at the bottom. But will cover less on the top while ON.
Just can't find the 14". And have a really nice offer. Buy one get one free on Goodyear wiper blades.
If you're willing to upgrade...go Trico NeoForm which come in 14"
Originally Posted by 2009BBPliftback View Post
While I love the look of the Neoforms I don't like that they chatter alot they are very very noisy
Do they chatter in both directions or just one way? If one way, your wiper arm(s) may be twisted a little bit. The blades must be 90 degrees from the glass and when it chatters one way and not the other, that's a sign the wiper arm(s) may be twisted. I've have absolutely zero chatter with NeoForms.
Lastly - FYI - They are running the rebates again but this time are allowing two per household. In Spring they only allowed one. Rebate info here.
Happy Fall Everyone!!
First Time Caller, Long Time Listener, Great Topic, Love The Show...Thanks For Taking My Call
jeff618 is offline   Reply With Quote
Old 10-08-2010, 11:54 PM   #2
krolos
Drives: 2008 yaris sedan
I changed out my stock wipers at around 35300 miles, I was surprized they
lasted that long, and they get alot of use here in the Pacific N.W., I
got my replacements at the Toyota Dealership , my Yaris just turned 36000 miles this morning and no problems
krolos is offline   Reply With Quote
Old 11-20-2011, 09:30 PM   #3
A-Dingo-Ate-My-Baby
Drives: yaris
Trico make a NeoForm exact replacement for the rear, additional plastic housing and special connector clip and all, just like the OEM. Yank old blade and housing all the way backward and it pops off a small clip.
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 11-21-2011, 11:23 AM   #4
jeff618
jeff618's Avatar
Drives: Mazda 3
Arrow Yaris Rear Wiper Blade
I can't find a rear neoform but I use their exact fit rear for the yaris: https://www.wipers123.com/detailed_p...?products_id=8
Install Video (Click xx-A): https://www.wipers123.com/wiper_blad...ion_videos.php
Old 08-25-2011, 04:12 PM   #5
Bmcguigan1
Bmcguigan1's Avatar
Drives: 2009 Toyota Yaris 5dr hb
WOW! I contacted my local Toyota Dealer to get the replacement inserts for OEM blades and they told me they didnt have them in stock and wouldnt order them because the had to order too many to be worth it for them!
Bmcguigan1 is offline   Reply With Quote
Old 08-26-2011, 10:16 PM   #6
GanjaBabe420
GanjaBabe420's Avatar
Drives: 2008 Toyota Yaris Sedan
Send a message via AIM to GanjaBabe420
Wow..that really sucks that they wouldn't order any for you..
I think I'm gonna go with the Bosch wiper blades that they have at Auto zone..
GanjaBabe420 is offline   Reply With Quote
Old 08-27-2011, 07:52 PM   #7
thepartsmancometh
Drives: '08 LB, '07 WRX
BS. Total BS. I work for a Toyota (and Ford) dealership in the parts dept. I can order 1 wiper insert, or 1 million. We don't even get a price break for ordering more. Why they don't want to do their job is beyond me.
thepartsmancometh is offline   Reply With Quote
Old 08-28-2011, 07:08 AM   #8
jeff618
jeff618's Avatar
Drives: Mazda 3
Arrow
I didn't switch to buying on line because of this type of thing, I switched because its so far of a drive and gas is so expensive. That said, your experience REALLY stinks. They obviously can't see the forest through the trees.
I still love the neoforms and its pretty cool that wipers123 sends me inspection reminders occasionallly so I always know how old my wipers are.
Old 11-20-2011, 08:59 PM   #9
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
My original blades were awesome...16 months later had to replace them....replaced them with Toyota blades......not impressed....definetly not the same that came from the factory!!!!....just like tires etc. .
frog13 is offline   Reply With Quote
Old 11-21-2011, 12:49 AM   #10
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
I've had the same pair of silicone triple edge wiper blades on my civic for about 7 years I think.....give or take a year or two each way......just got to clean them every few months. The suspension arms are sun oxidizing but they are still holding up......
Old 11-21-2011, 11:40 AM   #11
A-Dingo-Ate-My-Baby
Drives: yaris
oops ^ yeah I dun goofed, call the cyberpolice. that is what I meant. exact fit, same rubber but not a 'neoform'
Old 11-21-2011, 04:19 PM   #12
Still Learning
Drives: 07 Yaris 3Dr HB
I used neoforms on my minivan last winter. They are awesome wipers. I just ordered a set for the Yaris. I highly recommend them.
Still Learning is offline   Reply With Quote
Old 11-22-2011, 08:55 AM   #13
A-Dingo-Ate-My-Baby
Drives: yaris
...update
not 100% happy with the new Trico exact fit rear for the yaris HB
(the fronts are fine)
the rear loses traction at the tip furthest from the arm,
in the first 4 inches of wipe, from .1 to 1 inch to .1 inch wide.
failsauce. I have a peeve and it is any rear wiper with less than 100% contact.
I will need to regroup and try a new arm, or a new insert, or something
to calm my seething rage.
Old 11-22-2011, 09:18 AM   #14
jeff618
jeff618's Avatar
Drives: Mazda 3
Arrow
No problem - lol
Pretty quiet, hey?
...update
Sounds like you got a bad one or that the wiper is binding slightly on the arm or the arm is getting tight at the hinge. Make sure to carefully lubercate the wiper arm hinge and that the wiper blade moves freely. If you still have the problem after that...you got a bad blade.
Old 11-22-2011, 02:41 PM   #15
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
...update
trickos don't really work of the rear. i had the same issue, bought the whole blade from toyota, seems to work nicely. 10$ and you can change just the rubber from that point on. just keep the toyota blade.
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
Old 11-22-2011, 12:43 PM   #16
Still Learning
Pretty quiet, hey?
Yeah, very quiet. No squeaking noise at all.
Old 11-22-2011, 01:19 PM   #17
A-Dingo-Ate-My-Baby
Drives: yaris
figured out the rear Trico exact fit problem:
The Trico exact-fit replica wiper blade housing is close, but not exactly the same
as the OEM. The length stop-to-stop is 3mm longer. The Trico insert has some
wiggle room side-to-side, allowing the far-end of the insert to float off the glass
when pressure is applied to the middle of the insert
I slid the Trico insert out of the Trico arm, installed the Toyota arm, and slid in the
Trico insert. The Toyota stop tabs touch the insert at both ends of the blade, and when
the arm is at rest position, the stops hold the insert and keep it from floating off the glass.
So, in the case of: should I get a new insert, or a whole new Trico exact fit assembly ?
say NO to Trico, or just get the insert.
Other companies may make a better OEM-fit blade housing, but Trico dropped the ball on this one.
I now have 100% rear wiper contact. crisis averted.
Old 11-22-2011, 02:44 PM   #18
Yury
Yury's Avatar
may ask why not buy the toyota blade? doesn't seem expensive and you can replace the just rubber after.
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Wiper Blades futdechenes General Yaris / Vitz Discussion 44 06-27-2010 11:08 AM
What kind of wiper blades? buyah123 DIY / Maintenance / Service 9 11-25-2008 05:25 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
