Old 07-24-2009, 01:22 PM   #1
floydisrock
73 Centurion droptop 455
floydisrock's Avatar
Drives: 2009 S Sedan
Exclamation Air filter,primary and secondary
Anyone replace the primary and secondary air filters?
Anyone have the mileage interval?
I ordered some wix secondaries,but the primary's seem mighty expensive.
"THIS SITE HAS BEEN HACKED BY www.bimmerfest.com. YOU FUCKERS!"
floydisrock is offline   Reply With Quote
Old 07-24-2009, 03:02 PM   #2
Primary and secondary? Do you mean the carbon trap?
Old 07-24-2009, 03:33 PM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
What?
Old 07-24-2009, 03:35 PM   #4
WolfWings
WolfWings's Avatar
Yeah... the Yaris only has one air filter for the engine, and one for inside the A/C in the cabin. There's no primary or secondary to it, just one filter for each entirely-seperate purpose. And both are bone-simple to change and cheap as dirt.
Old 07-24-2009, 03:44 PM   #5
floydisrock
http://www.car-stuff.com/store/?N=11...725+11921+9157
I guess I ordered 4 wix primary filters at about $10 each.
I kept running into the listing for secondary filters,and couldn't figure out what they were talking about.
I'm guessing maybe it's the plastic cover?
The filter comes out easily,but I imagine it's easy to crack the hinge/housing.
Just a heads up.
Old 07-24-2009, 03:50 PM   #6
Yaris Hilton
Smile
I haven't looked in my air box yet. I've seen filters before that had a foam filter to catch the bulky coarse dirt before the air goes through the finer paper filter that removes the smaller dirt particles but clogs faster.
Old 07-24-2009, 08:14 PM   #7
BLH
Drives: 2007 Yaris Sedan
The break down on ToyoDIY.com actually shows a sub filter in the top of the housing.
I never even looked in the top part for a second filter.
BLH is offline   Reply With Quote
Old 07-24-2009, 10:37 PM   #8
The part shown on ToyoDiy is a white mesh filter that is probably there to keep anything that gets freed up when the filter is changed from making it to the MAF sensor. The EPC doesn't show it as being a separate part from the air box, so it is probably not intended to ever be replaced.
Old 07-26-2009, 07:51 PM   #9
b_hickman11
Drives: 08 Sedan
It's called a Carbon Trap.
Old 08-25-2009, 09:13 PM   #10
RedRide
RedRide's Avatar
I just replaced my air filter with a K&N.
I must admit that I'm a bit piuzzled by this secondary fillter.
I could understand if airflow was from top to bottom as it would keep anthing from "falling" into the intake.
However, since air flow is from bottom to top, it doesn't make much sense to me.
What is ment by it being a "carbon trap"?
Old 08-25-2009, 10:28 PM   #11
eric81
eric81's Avatar
Drives: Toyota Salesman
Carbo trap keeps stuff from going into the engine that doesn't belong, and stuff from leaving the engine the wrong way. Pointless, IMO. I took mine out right away, and had no problems. Take yours out, and try blowing through it. It's kinda hard. Now, imagine your engine going through that same strain. The less work the engine does to create power, the more power it has to put to the ground.
eric81 is offline   Reply With Quote
Old 08-26-2009, 12:06 AM   #12
RedRide
RedRide's Avatar
Isn't that what the "main" air filter is for? If the air filter is filtering as it's designed to do, what is the purpose of the secondary?
I agree that it limits air flow. Perhaps that's precisely what it's for?
Maby it's part of toyta's "tuning" to limit performance to increase MPG?
Old 08-26-2009, 12:51 AM   #13
YarisSedan
Drives: 08 Yaris Sedan
I think its there just as a precation. Which is why you have a noticible difference swapping to a performance intake verses stock. Because there is so much restriction to begin with.
Old 08-26-2009, 01:20 PM   #14
RedRide
RedRide's Avatar
Ok.... I just came from the Toyota dealer. I got my initial oil change using the VIP card they gave me. They are right down the road and have been changing the oil on my Celica for years. With a cupon it's realtively cheap also.
Anyway, I just happen to run into the service manager and I asked him about the purpose of the secondary air filter.
Now, he has been there for years (a major dealer in the NE) and we have had a few conversations in the past.
However, as far as the secondary filter, he admitted to me that he really didn't have clue about its purpose.
When I ran by him the things I heard it might be for (carbon trap etc) he when on to say that he has heard all that but, he has never heard or read anything official from Toyota to indicate what it was for and as far as he knows, it has nothing to do with emissions, etc as some suspect.
So, the mystery continues.
BTW, the K&N filter definately made a dfference in throttle response and is well worth it.
Old 08-26-2009, 02:07 PM   #15
b_hickman11
Drives: 08 Sedan
More Power=Lower MPG
Old 08-26-2009, 03:38 PM   #16
RedRide
RedRide's Avatar
Exactly my point in a previous post.
I suspect its only purpose is to increase MPG.
Old 08-26-2009, 03:55 PM   #17
RedRide
RedRide's Avatar
I just found this and it seems to shed some light on the matter:
A C&P---
".....;I have to rant...I love how everyone calls the carbon filter a "secondary air filter" even though it's not an air filter at all. It just keeps gas fumes from leaving the engine and adding to pollution. Those fumes get trapped in the carbon and then sucked back into the engine when you start it back up. So by removing the carbon filter, everyone's just venting those fumes into the atmosphere instead of using them when the engine is running. Might as well leave the gas cap off too. Personally, when I pay for all that gas I like to use it in running the engine rather than just letting it evaporate into the air."
I then read that this was done mainly to apease Califorinia's stricker emissions standards.
If all this is true, removing it will do no harm and will not effect emissions tests, except maby in California.
Old 08-26-2009, 04:09 PM   #18
So would it really be worth it to remove it and cause more pollution? I doubt it that it would cause a noticeable power increase.
Weapon R intake? AlphaFox Performance Modifications 77 11-14-2008 06:10 PM
air filter multipart btc50 DIY / Maintenance / Service 1 08-31-2007 07:37 PM
