Old 07-25-2009, 05:55 PM   #1
watersoilair
Drives: 08-2DR-MT-LB-Red
Thanks a lot for the tip...I was really starting to worry. This can be done on your own. The location of the shifting bushings is between the motor and the battery. I sprayed every rubber joint/apperatus and worked it around with the stickshift, then went around and did it once more. Make sure to use a silicone based lubricant as a petroleum based lubricant will degrade the rubber joints. Happy driving!
watersoilair is offline   Reply With Quote
Old 07-28-2009, 08:49 AM   #2
TylerJ
Drives: Blazing Blue 2007 3dr HB 5MT
Is white lithium grease silicone based ? Or are there different types and you need to get silicone based? I ask because it was mentioned earlier in the thread.
TylerJ is offline   Reply With Quote
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 04:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 11:41 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
