You only need a relay if you have another wiring harness which is really a good idea because the current draw when you first turn on your ballasts will fry your wires over time. My ballasts get powered directly from the battery - the factory wiring only serves to tell the relays on the new harness when the lights are on/off or high/low. The diode is on the new harness - if your kit doesn't have another harness, you won't have a diode.
I'm a little disappointed in the cutoff on the lighting. There is some reflection off the little doohickeys that control the high beams but overall, not bad. What isn't so good is I have to be really careful switching from high to low beams - if it bumps through the low beam position to the flash to pass position; one or both lights go off! Also, the high beam indicator doesn't work because there is no feedback from the bulb. I can live with both, I just have to be very careful when switching from high to low. Low beam: High beam: ![]() Low beam on road: ![]() Color (5,000k):
#2 | |
toyota
question!!
do you have to take ur bumper out to install the hid conversion kit.??
