Old 08-18-2009, 08:07 AM   #1
MGargano
Drives: 2009 Yaris Hatchback
I disconnected the battery overnight (about 13 hours or so) and tried it this morning... still nothing positive. All dash indicators are still lit.
Old 08-18-2009, 08:13 AM   #2
Try reading the codes from the SRS again.
Old 08-18-2009, 08:21 AM   #3
MGargano
Same as before- 32, 55, & 56
Old 08-18-2009, 08:27 AM   #4
Here is the procedure for manually clearing the stored codes (The SM says that some codes do not clear with a power down):
1. With a jumper, connect the TC and CG terminals on the OBD port.
2. When the SRS light starts flashing the codes, within 3 to 10 seconds remove the jumper frm TC. After 3 seconds the SRS light will come on solid.
3. Within 2 to 4 seconds after the SRS lights, reconnect the jumper to TC.
4. Within 2 to 4 seconds the SRS light will go off. Once it does, within 2 to 4 seconds disconnect TC.
5. Within 2 to 4 seconds the SRS light will come one solid again. Within 2 to 4 seconds after the SRS lights, reconnect the jumper to TC.
6. Within 2 to 4 seconds the SRS light will go off. One second later, if all DTCs are cleared the SRS light will flash steadily on and off. If codes are still registered it will flash in the pattern to indicate the stored codes.
Old 08-18-2009, 12:14 PM   #5
MGargano
Ok I'll give this a try ASAP. Thanks for posting the instructions.
Old 08-18-2009, 05:56 PM   #6
MGargano
Ok this is either impossible or I'm doing something wrong. It's really hard to read, interpret, and follow directions in 2-4 seconds. Also, the light is coming on solid immediately after disconnecting the jumper, not after 2-4 seconds so I'm not sure what's up there.
I thought I had it at first and was down to only code 32. Then I probed one of the weight sensors (still nothing!) and checked the codes again. Now I'm getting 32 and 55, but not 56. WTF?
Old 08-18-2009, 06:20 PM   #7
MGargano
2. When the SRS light starts flashing the codes, within 3 to 10 seconds remove the jumper from TC. After 3 seconds the SRS light will come on solid.
I'm getting stuck right at the beginning. The SRS light should come on solid after 3 seconds, but instead it comes on solid immediately after the jumper is disconnected.
Old 08-18-2009, 09:41 AM   #8
DorytheYaris
aka Eleni
DorytheYaris's Avatar
Drives: 10 Yaris LB Auto- Blazing Blue
Originally Posted by MGargano View Post
I'm looking to upgrade the front seats in my 09' hatch but I'm honestly not really sure what's out there, especially since some of the websites I checked out are crazy expensive. I'm just looking for something with good support, OEM function (sliding, reclining front and back, folding to let passenger's in back), and something lower to the ground.
I see these on fleaBay, but I'm not sure of the quality or fitment: http://cgi.ebay.com/ebaymotors/MAZDA...Q5fAccessories
Appreciate any help I can get with this.
If you get rid of your seats I WILL GLADLY buy your stock passenger seat from you! I need one desperately!!!!! and I am in NJ!!!
DorytheYaris is offline   Reply With Quote
Old 08-18-2009, 12:11 PM   #9
MGargano
If I do decide to sell the OEM passenger seat it will most likely be without the four weight sensors. I haven't made up my mind about getting rid of the OEM seats yet though. I want to get the new ones working 100% before I get rid of the old ones. I'll definitely keep you in mind though.
Old 08-18-2009, 12:14 PM   #10
DorytheYaris
aka Eleni
Thank you :)
Old 08-18-2009, 07:22 PM   #11
You might want to try two jumpers, where you can leave them on the pins and then connect them while your hands are up in visible range of the display.
Old 08-18-2009, 07:24 PM   #12
MGargano
That's actually what I tried. I have one pin in each connector and am connecting the two with an alligator-clip wire but it's still tough. That aside, it doesn't seem to be going the way the directions indicate it should with the flashes, solids, etc.
Old 08-18-2009, 07:32 PM   #13
MGargano
Ok, trying your idea I'm 99% I successfully cleared the codes. Well, codes 55 & 56 are gone, but code 32 remains flashing.
Old 08-18-2009, 08:24 PM   #14
Cool. At this point you must feel like your defusing a bomb.
Code 32 is the OCS. The issue right now is the lack of a base load on the sensors. They are calibrated for the weight of the empty seat.
Are you still measuring no voltage on the sensors?
Old 08-18-2009, 08:29 PM   #15
MGargano
I was measuring no voltage on the sensors with all the codes still flashing but I haven't tried it now with only code 32. Maybe they won't receive voltage if they don't sense any weight at all? The sensors are plugged into the system, but are just laying on the floor in the car.
Old 08-18-2009, 08:48 PM   #16
How about putting some pressure on each with a c-clamp or stacking them and using one clamp?
Old 08-18-2009, 11:09 PM   #17
MGargano
I'll try this tomorrow after work and report back
Old 08-19-2009, 07:57 AM   #18
MGargano
A preliminary run of this didn't seem to work but I only used one clamp per sensor. I'm also not sure which part is actually sensing the weight. Is it the four raised buttons on top?
Also, there is a threaded hole in the side of each bracket which goes through the black button in the right of this pic. It looks like the bolt goes through the button and touches the metal body of the sensor. I'm not sure if it's providing some kind of ground, etc.
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
