Old 08-24-2009, 05:32 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
I received the Eggo Waffle box today (and it was lacking waffles). I did a quick test of your OC ECU and it is fine, which means that the issue is either with one of the sensors or a wire. I'll check it out tonight to find out for sure. Either way, it won't really matter, as I'll be shipping it back to you with one of my sensor bypass modules.
Do you want me to clip the harness off and tie it directly to the module, to keep things neat under your seat? (I'll ship back the rest of the harness with the sensor connectors).
Glad it arrived ok and sorry for not including some waffles
Glad the ECU is working since it saves me time and money of getting a new one.
Yes, you can connect the bypass module directly to the ECU to save space and neaten things up under the seat. I'll hang on to the sensors and wires in case I go back to stock at some point.
Also, if it matters, I'm planning to mount the airbag switch in the center console near the e-brake.
Thanks!
Old 08-24-2009, 11:05 PM   #2
Thanks!
OK. Your module is ready to ship! I'll send it off tomorrow (to the return address on the waffles).
I checked out your sensors and cable tonight as well. The sensors are fine. The sensor connectors on the cable are the problem. When you probed some of them, you forced the probe in enough to damage the pins. So, if you ever go back to stock, you'll need to replace those ends.
Old 08-24-2009, 11:13 PM   #3
MGargano
Awesome! Damn that was fast! I'm glad the ECU and sensors are good. Do you, by chance, have a part number for the sensor harness, in case I want to order a new one?
Also, did you get a chance to look into the push-button stuff I PMed you?
PS- How much $$$ do I owe you for all this?
Old 08-24-2009, 09:02 PM   #4
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
wow CTScott you are making great progress.
Garm if you purchase a set in bulk i will be one of the first buyers.
this is great
Old 08-24-2009, 11:23 PM   #5
I'm on vacation this week to get the kids ready for school, so I had some time today.
I hit you back with a PM on the push-button start stuff.
As far as the $$$ goes, it'll be $50. But, wait until you get it and have it all hooked-up and working before you pay me.
Old 08-24-2009, 11:25 PM   #6
MGargano
Ok, thanks! Can't wait to get this working!
Old 08-25-2009, 08:37 AM   #7
So, here is the completed module that I am shipping to you. With clipping the connector from the original harness, it makes for a very neat installation. The wire for the switch is 4 feet long, which is way more than enough to reach the console, where you intend to install your switch. The switch in the picture is just one that I popped on for testing.
Old 08-25-2009, 05:45 PM   #8
MGargano
Attachment 27606
That looks amazing!!! Thanks so much!
Old 08-25-2009, 11:31 AM   #9
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Looks great!!! You do really good work
Old 08-25-2009, 02:55 PM   #10
heeroyuy01195
Post count means nothing.
this is awesome! Scott...you are the man! subscribed :)
Old 08-26-2009, 06:13 PM   #11
MGargano
Got the module today and this thing is HOT! I'm assuming I just need a 12 volt on/off switch to arm/disarm?
Old 08-26-2009, 07:16 PM   #12
Any switch will do, as it is switching 5 volts with no current. If you use an illuminated switch, just make sure that the illumination has separate contacts from the switching.
Old 08-26-2009, 07:17 PM   #13
MGargano
I just finished the install and the module is working 100% perfectly! SRS light went out immediately and the passenger's airbag and seat belt lights are functioning like OEM.
CTScott... you, sir, are without a doubt THE MAN!
Old 08-26-2009, 07:47 PM   #14
lilredrocket
Slowy getting there
Drives: 08 Liftback
Ok now for the final install pics!!!!
Old 08-26-2009, 07:56 PM   #15
MGargano
I'm actually house-sitting for a friend this week until next Monday, but I'll definitely post install pics when I get back home to my camera.
Old 08-26-2009, 08:50 PM   #16
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Now your letting the team down
Old 08-26-2009, 09:30 PM   #17
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
try reading through the pages....anyone could do a DIY and when the module of ctscott will be available for us to purchase? thanks!
Old 08-26-2009, 09:38 PM   #18
MGargano
At this point a DIY is kind of unnecessary since the only way to get everything working is CTScott's module, which literally takes second to plug in.
Aside from his module, there's really no other way to get the system to function like OEM, unless you figure a way to mount the weight senors to your new seat/bracket.
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
