Old 08-07-2009, 04:31 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
MGargano is offline   Reply With Quote
Old 08-07-2009, 04:31 PM   #2
Much better...
Old 08-07-2009, 04:40 PM   #3
If I end up picking up the wrecked eBay Yaris, I'll have a set of seats to mess with the sensors. They appear to be resistive load cells.
Is there enough space under the new seat for the Occupant Classification ECU?
Old 08-07-2009, 04:42 PM   #4
MGargano
Is that this guy?
Old 08-07-2009, 04:44 PM   #5
Yes. He'll need to still be connected.
Old 08-07-2009, 04:45 PM   #6
MGargano
Not really any room under the seat or on the brackets:
Old 08-07-2009, 04:46 PM   #7
MGargano
Is it safe to just lay it on the floor under the seat?
Old 08-07-2009, 04:53 PM   #8
MGargano
Scratch that... I can attach it to the front of the bracket
Old 08-07-2009, 04:59 PM   #9
How about the seat belts - Are you going to use the exiting or replace them with harnesses?
Old 08-07-2009, 05:01 PM   #10
MGargano
I'm using the existing belts. I already removed the seat belts from the old seats and bolted them to the new ones.
Old 08-07-2009, 05:01 PM   #11
MGargano
Booya!
Old 08-07-2009, 05:08 PM   #12
MGargano
Apparently the driver's side seat belt is not the same as the passenger's side. Driver's side is plugged into this:
Old 08-07-2009, 05:10 PM   #13
MGargano
No idea what this is, but it's magnetic... stuck to the rail when I removed the torx screw holding it in.
Old 08-07-2009, 05:35 PM   #14
MGargano
I attached it to the driver's side bracket. Seat belts officially swapped!
Old 08-07-2009, 05:56 PM   #15
MGargano
*patiently awaits the next step*
Old 08-07-2009, 07:01 PM   #16
MGargano
Ok, I plugged the 3.3 ohm resistors into the airbag sensors and installed 10k ohm resistors between Pin 1 (SVC) and Pin 2 (SIG) and 470 ohm resistor between Pins 2 & 3...
I'm getting the SRS warning light in the instrument cluster, Passenger Airbag 'Off' and passenger seat belt light blinking....
Old 08-07-2009, 07:08 PM   #17
MGargano
...so now I'm totally lost. Help!
Old 08-07-2009, 08:24 PM   #18
Did you disconnect the battery while you were unplugging the airbag, etc? If not, disconnect it for a couple of minutes and then reconnect it to reset the SRS ECU.
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
