yes I know I will need a wideband sensor when I have a turbo but for now I want to know in general where the car should be. Since it will probably be several months, more than likely a year, before I get enough money for a turbo I can see spending $40 to learn where the car should be and how it acts before spending around $230 on the good stuff. Thank you for your concern ChinoCharles
Who said Yaris was slow?
Do you realize that the information that this gauge will give you is prety much useless...
![]() I would try to get my money back and get a a boos, oil presure or water temp guage instead. All of them will be useful later on. A narrow band AF gauge that it doesn't even give you the data in a digital format has no benefit at all... it won't tell you where the car should be and won't tell you how the car reacts. Only a true wideband can do that. |
My next gauge will be an oil pressure gauge but I think that a boost gauge before you have a turbo would be a little tacky don't you think lol. Don't worry I will get a wideband eventually. Put it this way, I gained valuable experience working with the wiring and learned wear my sensors are while having something to look at with pretty lights for awhile
Also I can probably take apart my dash in like 2 minutes now that I have had it on and off so many times |
#4 | |
where your car should be on boost is between 11.1:1 and 12:1 depending on boost levels. there, free advice ;)
Thanks for not charging
| The "let's brainstorm how to make a piggyback work" thread | eTiMaGo | Forced Induction Forum | 83 | 08-17-2011 03:54 PM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 06:42 PM |
