Old 07-31-2009, 11:15 AM   #1
texkid
The one with cheese on it
Drives: '10 Corolla S
Ouch on that cut around the stalk. Isn't there a molded cut line in the plastic that you could have followed?
Kind of. But it was too late because I didn't see it until I connected the wires to the stalk. It is supposed to rain this weekend, so hopefully things will cool off. If it does, then i'll the airbag off and take a picture.
DIY: A/C Insulation
texkid is offline   Reply With Quote
Old 07-31-2009, 11:35 AM   #2
If you decide to replace the cover, the part number is:
Cover, Steering Wheel Boss, Lower: 45184-52130-B0
This part number is supposedly for the one with the cruise control hole already there.
Old 07-31-2009, 11:47 AM   #3
texkid
I had thought buying the wheel cover but decided to hold until I bought the shifter extender which is next on the list. I will eventually get that wheel cover though.
DIY: A/C Insulation
Old 08-16-2009, 11:08 AM   #4
2+2
Drives: 09 3Dr Manual
Just to confirm. Yup, that's the correct part number. I just received it yesterday and I'll be installing it as soon as the stalk arrives from Thailand. 16 days and counting since I placed the order.
For future cruise control installers: the part has the factory perfect hole already cut out for the cruise control stalk. The price from Sparks was $21.82 plus shipping. I also ordered the clutch switch (88280-14030) for $14.86 from them.
2+2 is offline   Reply With Quote
Old 08-17-2009, 05:46 PM   #5
2+2
I got my stalk from Thailand today and installed it in my 09 3dr MT.
The clutch switch: Maybe no one mentioned it because it's so obvious but at least on the 09s there's a piece of black plastic under the dash that blocks the view of where the clutch switch goes. There's only 2 screws that hold it in place and once you remove it you can see where the switch goes without learning yoga. I wish I had paid more attention to how far the original clutch pedal adjustment bolt was before I installed the switch so I'd be sure I adjusted it correctly. My first thought was to screw it in until the clutch pedal began to move and then stop. But the pedal didn't feel quite right at the top of it's travel so I gave the switch a couple more turns. Is that right? Doesn't matter with a hydraulic clutch does it?
The steering wheel and stalk: Everything went really well thanks to all the good pointers here But of course box-o-rocks me had to try and make it interesting. I ordered the wrong stalk. Mine didn't have the horn wire hanging off the connector like
I ended up reusing my original horn wire by freeing the wire and connector from the plug and plugging it into the connector on the end of my stalk.
Thanks to everyone that worked on this I've now got cruise control and it didn't cost an arm and a leg and it was fun to do.
Should I worry about my clutch pedal adjustment?
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
