#1 | |
Cover, Steering Wheel Boss, Lower: 45184-52130-B0 This part number is supposedly for the one with the cruise control hole already there. |
The one with cheese on it
Drives: '10 Corolla S Join Date: Oct 2008
I had thought buying the wheel cover but decided to hold until I bought the shifter extender which is next on the list. I will eventually get that wheel cover though.
DIY: A/C Insulation |
#3 | |
![]() ![]() ![]() Drives: 09 3Dr Manual Join Date: Jul 2009
![]() For future cruise control installers: the part has the factory perfect hole already cut out for the cruise control stalk. The price from Sparks was $21.82 plus shipping. I also ordered the clutch switch (88280-14030) for $14.86 from them. Last edited by 2+2; 08-17-2009 at 02:22 PM. Reason: Added some info |
I got my stalk from Thailand today and installed it in my 09 3dr MT.
The clutch switch: Maybe no one mentioned it because it's so obvious but at least on the 09s there's a piece of black plastic under the dash that blocks the view of where the clutch switch goes. There's only 2 screws that hold it in place and once you remove it you can see where the switch goes without learning yoga. I wish I had paid more attention to how far the original clutch pedal adjustment bolt was before I installed the switch so I'd be sure I adjusted it correctly. My first thought was to screw it in until the clutch pedal began to move and then stop. But the pedal didn't feel quite right at the top of it's travel so I gave the switch a couple more turns. Is that right? Doesn't matter with a hydraulic clutch does it? The steering wheel and stalk: Everything went really well thanks to all the good pointers here ![]() I ended up reusing my original horn wire by freeing the wire and connector from the plug and plugging it into the connector on the end of my stalk. Thanks to everyone that worked on this I've now got cruise control and it didn't cost an arm and a leg and it was fun to do. ![]() Should I worry about my clutch pedal adjustment? |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
