Old 07-31-2009, 04:54 PM   #1
Originally Posted by BrianS View Post
Odd question here. I actually had the aftermarket Rostra cc put in. I prefer the OEM look tho. If I wanted to get the OEM stalk and install that instead, would I have to start from scratch, running all those wires or could I utilize the wiring the Rostra has coming to it somehow?
I looked at the Rostra installation instructions and it actually connects to the ECM via the accelerator position sensor input. It has inputs to its own module from the brake pedal and gas pedal as well. Basically, it does the cruise control thing the way it would be done on a car who's ECM doesn't do it, so the bottom line is that none of the Rostra wiring would be of any value, if you switched to the OEM method.
Old 07-31-2009, 04:58 PM   #2
BrianS
Drives: 2007 Yaris 3DR LB
Ah darn! LOL! I was trying to avoid tearing my dash apart. Thanks for the reply tho CTScott. :)
BrianS is offline   Reply With Quote
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
