Old 07-28-2009, 09:41 AM   #55
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
Originally Posted by Split View Post
do you have an exhaust system as well? I'm baffled that you'd drive so much with an intake and header, doesn't the noise get to you after a while? I suppose if you have the factory muffler on you're probably okay.
I have a dynomax exhaust, but cruising at 70mph, you don't hear any intake or exhaust noise. The car is almost as quiet as factory while cruising.
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 07-28-2009, 09:42 AM   #56
trini_per4mance
In your Youtube links its says under 'more info' you are running under drive pulley/s...so not anymore? or is it a c-one brand?
I had an NST pulley, but I sold it.
Old 07-28-2009, 12:14 PM   #57
regal
Drives: 09 Yaris 3 Dr White LB
the mechanical head/valves is the achilles heal of this engine, it is a very involved jon to adjust them, at 350K they definately need adjustment. But It would be cheaper to drive till a valve drops and replace with a low milage JY pull.
regal is offline   Reply With Quote
Old 07-28-2009, 12:36 PM   #58
bronsin
bronsin's Avatar
Yes its probably asking a lot for a Toyota mechanic to adjust these valves. No other Toyota uses this system. And there are very few ECHOs/Yaris's sold compared to other Toyotas. You might be better off taking the car to a motorcycle mechanic because this system is common on motorcycle engines. Although....it IS relatively easy to CHECK the valve clearances for the home mechanic. Its adjusting them thats involved.
Old 07-29-2009, 01:05 PM   #59
jemmah
Drives: Toyota Yaris
High Miles Issues
I got a Yaris (2007) which is 18 months old and 81K with no problems yet! Also have a 2005 Ford Ranger with 378K. Started to ping sometime back and I was using high test so I wouldn't have to listen to the marbles in the engine. Finally had Ford look at it and they stated that the time chain had streched. I told them it wasn't worth it to replace the chain so they reset the timing to a place where the pinging stopped. Don't know whether it was advanced or retarded. Now I'm back to low test fuel and I really don't feel a major difference. So add the chain to all the possible pinging issues.
JEM
Last edited by jemmah; 07-29-2009 at 01:07 PM. Reason: Didn't mention year of Yaris
jemmah is offline   Reply With Quote
Old 07-29-2009, 04:25 PM   #60
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
How much mileage did you put on the NST pulley before you sold it and why sold it? cause NST pulley's will be my next mod.
Old 07-30-2009, 12:20 PM   #61
trini_per4mance
Guys, the pinging that I'm hearing is very rear and I only hear it for like a second or two when the engine is under 99% load sometimes. I don't think it's my valves or timing chain, but then again, I may be wrong. I think is has to do with the fuel and the fact that my O2 sensors and knock sensor have 350K miles on them. So, they may not be functioning 100%.
Old 07-30-2009, 12:37 PM   #62
Kal-El
Kal-El's Avatar
So do you have a video made of the 350,000 rollover? Post it up!
Old 07-30-2009, 04:48 PM   #63
toyo
Drives: toyota
ohh my god that is freaking awesome!!!!! you should contact toyota inmediatly and get sponsored, discounts and you could be on TV lol
awesome dude, freaking awesome..
1st gen FTW
toyo is offline   Reply With Quote
Old 07-31-2009, 02:37 PM   #64
trini_per4mance
Yes, I do have a video. But I need to get someone who can edit it and add captions and music to it. I would like to do a compilation of all the vids I have, from the 100k mile vid up to the most recent 350k vid. Anyone willing to help me out with doing this? I would greatly appreciate it. Thanx!
Old 07-31-2009, 02:52 PM   #65
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
WISHFUL THINKING. sponsorship from toyota
Old 08-03-2009, 08:23 PM   #66
R2D2
Crazy Oil Sniffer
R2D2's Avatar
trini,
Any update on the "ping" issue after the MAF cleaning, injector cleaner, etc?
TIA
R2
-The Fitful One
Old 08-03-2009, 08:54 PM   #67
trini_per4mance
Originally Posted by R2D2 View Post
trini,
TIA
R2
Yeah, it's almost gone. I very rarely hear it for a second once in a blue moon.
Old 08-03-2009, 09:05 PM   #68
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Cool, thanks!
R2
-The Fitful One
Old 08-10-2009, 05:25 PM   #69
Split
Drives: 2008 Yaris Sedan
Question
i thought you had a magnaflow exhaust?
Split is offline   Reply With Quote
Old 08-10-2009, 06:32 PM   #70
Red Horse
Red Horse's Avatar
Maybe if you have time you can create a "View User's Garage" so we can see what's your yaris mod's and some pictures.
Old 08-10-2009, 08:39 PM   #71
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
Congrats! :D
Twistoffate0817 is offline   Reply With Quote
Old 08-11-2009, 11:27 AM   #72
trini_per4mance
I have either a dynomax or magnaflow oem replacement exhaust with 2.25" inlet and outlet with a stock looking elbow tip facing down. I wanted the performance but keep it looking stock as possible.
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
