Old 08-04-2009, 05:22 PM   #1
redride, that is a great inexpensive way to "test" a shop. Did they torque the bolts correctly, doing the job "to spec", so to speak?
Old 08-06-2009, 12:32 PM   #2
RedRide
RedRide's Avatar
I doubt that they torqued the bolts.
To be honest, if I installed it, I wouldn't have torqued them either (even though I have a torque wrench) due to the limted room when installing it on the ground with the wheels still on.
Ater a while one gets a feel just just by looking at a bolt and its application to determine how much to tighten it.
So far, eveything seems tight as it should be.
I will check them is a couple of weeks to be shure they are still properly tight.
I really like my sway bar.
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
DIY - TRD rear sway bar kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 01:21 PM
