Old 08-09-2009, 11:52 PM   #1
^ Any pictures? I'm sure there would be a lot of interest in seeing that.
Old 08-10-2009, 12:20 PM   #2
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Safely means: "You don't blow your engine when you are doing a WOT pass" It doesn't mean that it will last the same as if you let your engine stock.
If a STOCK Yaris engine was supposed to get 350,000 miles before a rebuild... a boosted Yaris will get there sooner.
How sooner? There is no straight answer. Depends on the maintenance, and mostly in how you drive your car.
Upgraded internals such as forged pistons and rods are not intended to increase longevity... Those are made to increase the engines ability to handle higher boost levels. Usually when you built an engine is because is going take some abuse... Longevity is not a major concern for people who spend the big bucks building an engine.
Realiability, longevity = STOCK
can't beat that.
Old 08-10-2009, 07:49 PM   #3
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
we discovered that when we took out the pistons for ceramic coating last round. i promise i will take pictures and post it up when we crack open the engine for rebuild. recently ordered toga bearings from IPP, will take some time for the shipment to reach Malaysia.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 02-05-2010, 12:51 AM   #4
changchewsoon
Drives: Vios Turbo
some pics of the bearings that i took now that the engine is out for rebuilt.
Whistle at idle - vacuum leak, induction side RichieRoo General Yaris / Vitz Discussion 17 12-16-2022 05:53 AM
TC swap? MicroHB Performance Modifications 38 03-26-2009 12:39 AM
Induction with an Auto-Trans. Sweet Mercury Forced Induction Forum 7 09-08-2007 03:15 PM
Engine mods - why bother? RallyYaris Performance Modifications 143 12-24-2006 03:56 AM
