View Poll Results: Which HID kit would you be more intereste in?
HID with halogen high beam for about $80 6 9.52%
HID with true high/low beam for about $20 more 57 90.48%
Voters: 63. You may not vote on this poll
Old 08-10-2009, 10:36 AM   #1
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Originally Posted by MGargano View Post
I installed the XenonVision bi-xenon kit in my '09 with HID fog lights and OEM fog stalk and have retained OEM control over the fog lights (including dash indicator), but lost the blue hi-beam indicator in the instrument cluster.
Yeah...that is what I was referring to. Does the Halogen Hi-Beam and xenon low beam configuration by Xenon-Vision retain the high Beam indicator in the dash? The only negative to this configuration that I know of is that the light cutoff is not as good as with the bi-xenon.
DerFlosser is offline   Reply With Quote
Old 08-10-2009, 12:54 PM   #2
kargoboy
kargoboy's Avatar
Drives: '07 Yaris Sedan/'03 Protege
Originally Posted by DerFlosser View Post
Garm,
Would the use of this HID kit allow me to retain my DRL module (for fog lights) while, at the same time, allow the high beam indicator to work in the dash panel? My biggest hang-up so far in purchasing an HID kit is one that will allow me to retain stock features such as the two thing mentioned
The DRLs should not be affected.
Depending on the wiring setup I could see how this might happen, since all HID kits are not the same. However, it is also possible you've wired them wrong. H4 H/L (Xenon-Low/Halogen High) kits plug into your wiring harness
the same way the stock bulb would. One connection to control each bulb.
If it's wired correctly there should be no difference from stock.
However, some Bi-Xenon kits use a single bulb which moves from low to high position and it's possible that you could lose the high-beam indicator, depending on the wiring configuration.
IMHO, Bix-Xenons are complete overkill. I have been running HIDs for several years and they light the road so nicely that I only use the Highs to flash.
kargoboy is offline   Reply With Quote
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
KLight HID Conversion Group Buy!! $165.00 shipped!! JRT lighting Sponsors Classifieds Area 4 11-20-2006 10:47 PM
