yes it's ALMOST the same. If the air/fuel ratio is the same and the amount of air is the same, then the fuel used is the same.
However, as injectors get bigger (for the same purpose) the resolution goes down. My 632cc injectors are at a VERY low duty cycle when not in boost, so I am using up some extra gas because of that.
| 1zz injectors suit the S/C just fine | LtNoogie | Forced Induction Forum | 51 | 04-30-2016 10:11 AM |
| Can the Yaris handle 6psi with stock ECU, injectors and fuel pump? | trini_per4mance | Forced Induction Forum | 19 | 05-06-2009 01:18 PM |
| bigger injectors? | xxae07xx | Performance Modifications | 6 | 12-31-2008 05:04 PM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
| Technical Question for the Suspension Gurus | KwonSau | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 06-21-2007 11:31 PM |
