Old 08-17-2009, 10:31 PM   #1
Chrsto4
Chrsto4's Avatar
Drives: 2008 Yaris RS 5-dr HB Black
So if it came from the dealer with cruise already in the stalk, will those two wires on the clock spring still be available to hook up to the steering wheel controls? And are two enough if the Scion xD steering wheel has 5 functions (Mode, vol up/down, + -)? Pardon my ignorance on the electronics side. Thanks to you both so far.
Chrsto4 is offline   Reply With Quote
Old 08-17-2009, 10:41 PM   #2
If the cruise stalk is factory (i.e. on the right side of the steering wheel) then the wires are in use. If it is dealer/port installed (stalk on left side) then the wires are still available.
The buttons are multiplexed to work over a single pair of wires.
Old 08-27-2009, 12:42 AM   #3
goku87
goku87's Avatar
Drives: Black HB
Correct. Unfortunately my aftermarket HU doesn't support steering wheel controls. On my Xterra I modified the OEM steering wheel controls to work with the Sony HU I put in it (just had to change the resistor network).
1st Question:
What would be so hard about putting in a few extra wires?
2nd Question:
In regards to your not being able to connect the controls to the head unit, if your head unit has a remote, and you are willing to sacrifice that remote, it should be easy to re-wire all the buttons on the steering wheel to the buttons on the remote to control the HU, provided you can add more wires to begin with (see previous question...?).
goku87 is offline   Reply With Quote
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
Steering wheel audio controls? vodkalush In Car Entertainment + Electronics (audio / video / alarm) 14 09-13-2006 11:17 PM
