Old 08-18-2009, 08:05 AM   #1
Keith Tinari
Scrubble with a poke.
Keith Tinari's Avatar
Drives: 2009 Yaris LB
Originally Posted by teejay View Post
what tire size you running? and can you get a pic of how much it pokes in the front?
Originally Posted by TheRealEnth View Post
If you get some spacers for the rear... it will look super sick trust me =) ive got an effective +17 on the rear
http://www.penguingarage.com/HubSpacers/Spacer.html
Im running 205/50/15 toyo proxes4. Great tires for the money. I didnt want to go with a tire that was too agressive for the wetter weather.
I really do want to go with spacers but Im kinda scared for when the coilovers go on. I want the car at least another inch lower in the front and half an inch in the rear. You dont think it will Rub? I was rubbing on a rim an inch smaller than these, same offset and same 5mm spacer in the rear.
"If you cannot find truth right where you are, where else do you expect to find it?" Dogen
Keith Tinari is offline   Reply With Quote
Old 08-18-2009, 01:46 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
you'd HAVE to add a little rear camber, which would really look slick IMO. that plus camber bolts up front and you could have a very nice aggressive stance, especially in a front-view.
theoretically you're running 62.25MM outboard. Carlos's car is running 71.9MM outboard. he's also on a 195 tire. that taken into account, you may be able to pull of a 10mm spacer (effective +22MM ET rear, 72.25MM outboard) as long as you add a little camber to help tuck that 5mm outboard extra rubber.
(all numbers are math based, and do not represent actual dimensions. a 7.5" wheel is NOT 7.5" wide at its extreme edge)
FS: Drag DR-20 Wheels 15x7.5 +38mm offset BOBBO701 Items for Sale by private party 6 04-10-2009 11:28 PM
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
