Old 08-18-2009, 08:27 AM   #1
Here is the procedure for manually clearing the stored codes (The SM says that some codes do not clear with a power down):
1. With a jumper, connect the TC and CG terminals on the OBD port.
2. When the SRS light starts flashing the codes, within 3 to 10 seconds remove the jumper frm TC. After 3 seconds the SRS light will come on solid.
3. Within 2 to 4 seconds after the SRS lights, reconnect the jumper to TC.
4. Within 2 to 4 seconds the SRS light will go off. Once it does, within 2 to 4 seconds disconnect TC.
5. Within 2 to 4 seconds the SRS light will come one solid again. Within 2 to 4 seconds after the SRS lights, reconnect the jumper to TC.
6. Within 2 to 4 seconds the SRS light will go off. One second later, if all DTCs are cleared the SRS light will flash steadily on and off. If codes are still registered it will flash in the pattern to indicate the stored codes.
Old 08-18-2009, 12:14 PM   #2
MGargano
Drives: 2009 Yaris Hatchback
Ok I'll give this a try ASAP. Thanks for posting the instructions.
Old 08-18-2009, 05:56 PM   #3
MGargano
Ok this is either impossible or I'm doing something wrong. It's really hard to read, interpret, and follow directions in 2-4 seconds. Also, the light is coming on solid immediately after disconnecting the jumper, not after 2-4 seconds so I'm not sure what's up there.
I thought I had it at first and was down to only code 32. Then I probed one of the weight sensors (still nothing!) and checked the codes again. Now I'm getting 32 and 55, but not 56. WTF?
Old 08-18-2009, 06:20 PM   #4
MGargano
2. When the SRS light starts flashing the codes, within 3 to 10 seconds remove the jumper from TC. After 3 seconds the SRS light will come on solid.
I'm getting stuck right at the beginning. The SRS light should come on solid after 3 seconds, but instead it comes on solid immediately after the jumper is disconnected.
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
