Old 08-18-2009, 12:48 PM   #1
Vince87
Drives: 2007 2DR Yaris
Thanks CTScott ! you always have the answer faster than anybody else... is there's a more straightfoward route to the fuse box than the grommet under the carpet on the passenger side (thats were the Pin40 and my amp wires a going to the engine bay) ?
ps. I thought that the white wire was a ground, thats why I believed I could ground it on the chassis instead...
Vince87 is offline   Reply With Quote
Old 08-18-2009, 01:41 PM   #2
You can go through the driver's side grommet, which goes in up behind the inside fuse panel and comes out just behind the battery.
White with a black stripe is always ground on the Yaris. Solid white is often 12 V power (which is the case with the wiring for the clutch switch).
Old 08-18-2009, 02:01 PM   #3
Vince87
Nice thanks ! I didnt wanna have a wire hanging loose from one side of the engine bay to the other...
ps for those who waited for a clear DIY with pictures for the 07-08 LB (with or without MT) I will built one this week !
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
