Old 08-18-2009, 04:38 PM   #1
You will still need the trim kit, such as the Scosche TA1465B. It is not pictured, because it is not a Toyota part. The Toyota part that you ordered allows a Toyota radio to be mounted in place of the one you had. The Toyota radios are 20mm wider than standard DIN width, so the Scosche or Metra trim kit fills the gap for mounting a normal double DIN radio. You will also need the harness adapter (Scosche, Metra, etc), if you want to wire your new radio without cutting off the OEM connectors.
Stupid question about installing a radio fmicle In Car Entertainment + Electronics (audio / video / alarm) 6 05-26-2007 04:20 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
