Old 08-18-2009, 04:44 PM   #1
Henry G.
Drives: 2008 Yaris HB
TSB calling for 5w-20? Where, post link please.
Henry G. is offline   Reply With Quote
Old 08-19-2009, 09:45 AM   #2
craigq
Drives: '07 Yaris, '12 GLI
I'm only posting this and nothing else. If your car is under warranty still and can't make up your mind about an oil just stick with whatever oil is recommended on your oil cap/in your owner's manual:
It's linked to on stickied TSB thread
It's on Etimago's website
There's a couple running rampant on Yaris World
craigq is offline   Reply With Quote
Old 08-21-2009, 10:40 AM   #3
TheSilkySmooth
TheSilkySmooth's Avatar
+1 on this comment. The TSB says the new Toyota recommended oil is ILSAC GF4 NOT that its OK to use 5w-20 in an engine spec'd for 5w-30. See the BOLD NOTICE at the top of the TSB. It says to use what is on the cap and in your manual. What the TSB means is if you have a 5w20 oil cap and manual spec you can use ILSAC GF4 oil instead of GF3 without reservation (given GF4 is "eco friendly" with a lessened % of phosphorous and zinc anti wear agents, commonly called ZDDP or by penzoil in the past, Z7. Tried 5w-20, went around the block, and the engine was so noisy I thought it would explode before I got it back home.
Old 08-21-2009, 10:44 AM   #4
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Thanks for that correction, SilkySmooth. I didn't read the TSB. It's been referenced on here several times as OK'ing 5W-20, and I repeated what I'd read.
Old 08-21-2009, 08:21 PM   #5
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Originally Posted by TheSilkySmooth View Post
... Tried 5w-20, went around the block, and the engine was so noisy I thought it would explode before I got it back home.
This is such a crock.....clearly you must have had no oil in the car if this happened.
DerFlosser is offline   Reply With Quote
Old 08-22-2009, 11:14 AM   #6
1stToyota
1stToyota's Avatar
+1 on this comment. Tried 5w-20, went around the block, and the engine was so noisy I thought it would explode before I got it back home.
Well, I know you're certainly not the first member here that went back to 5w30 after trying 5w20, stating that more noise was noticed with a 5w20 fill.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 08-22-2009, 07:19 PM   #7
DerFlosser
DerFlosser's Avatar
Drives: Yaris
I'll be changing the oil in 2 weeks and I'll let you know if there is any audible difference. I am guessing that there will be zero.
Old 08-24-2009, 08:15 AM   #8
1stToyota
1stToyota's Avatar
I'll just go by what you and other members say. Some notice a difference, some say no change. I myself don't know about the NZ because I've always stuck with the 5w30 so far.
2008 Scion xD
Old 08-19-2009, 09:50 AM   #9
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Look above you in this forum and it's in the TSB sticky
Old 08-19-2009, 09:56 AM   #10
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I use the synthetic 0-20 in the winter and 5-20 in the summer,if i lived in Texas i might go for the 5-30 in the summer and 5-20 in the winter.
