Old 08-19-2009, 12:33 PM   #1
Originally Posted by DorytheYaris View Post
I thought the seat had all kinds of wiring because of the airbag and weight sensors though?
...sorry I am a chick and I really have no idea how car wiring works.
If the seat is removed and the car is powered on while the seat is absent, you will log a bunch of codes in the SRS system (and the SRS light will stay lit). The codes can fairly easily be reset by following a procedure that involves connecting and disconnecting a jumper a bunch of times. If you are going to remove the seat It is a easier to disconnect the battery first (and leaving it disconnected until the seat is back in) to avoid having to deal with resetting the SRS. And, yes there are a few cables that have to be disconnected to remove it.
Old 08-19-2009, 12:35 PM   #2
DorytheYaris
aka Eleni
DorytheYaris's Avatar
Drives: 10 Yaris LB Auto- Blazing Blue
Okay. If I decide to take the entire seat out I will definitely have to refer back to your instructions. I wish there were a simple solution (but there never is!)...
DorytheYaris is offline   Reply With Quote
Front seat modification. Increase thigh support. PetersRedYaris DIY / Maintenance / Service 36 08-22-2018 01:37 PM
front seat room Bigdaddy727705 General Yaris / Vitz Discussion 9 10-30-2013 11:26 AM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
front seat removal/reinstall mark schofield DIY / Maintenance / Service 2 01-25-2009 07:29 PM
FS: Extra Set of Fat Cat Front Bumps Stops Galavoxx Items for Sale by private party 1 07-03-2007 08:58 PM
