Old 08-19-2009, 01:08 PM   #1
Inspector14
Drives: 09 Yaris hatch, Meteor Metal
i am apprehensive about using a 0w-30 in the summer. i would like to use the castrol syntec 0-30 (good german stuff) just not sure if 0w-30 is too thin for the engine when cold?
Inspector14 is offline   Reply With Quote
Old 08-19-2009, 02:36 PM   #2
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
0W-30 is certainly not too thin. In fact at room temp GC is slightly thicker than Mobil 1 5w-30 (66.8 vs. 64.8 cst, respectively.) The first number in the viscosity classification is a number that indicates the oils relative performance in the cold-most specifically cold cranking. It will be about the same thickness at operating temp as a 5W-30 or a 10w-30. (See second link below).
Here are some links to some info I originally passed on to DerFlosser when he asked a question about seasonal oil changes. The second link provides a link to a series of papers that is a goldmine of information about viscosity and hopefully can clear some of the confusion regarding oil viscosity classification.
http://www.yarisworld.com/forums/sho...46&postcount=3
http://www.yarisworld.com/forums/sho...21&postcount=7
You should be OK with a 0W-30 as far as warranty because they do not warn against it and other than cold crank specs the viscosity is almost identical to a 5W-30.
My first choice would be a 5W-20 in the Yaris REGARDLESS of environment, ALASKA or TEXAS. I would recommend 0W-20 post warranty but would not use it under warranty because the TSB specifically warns against it (which makes no sense).
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 08-19-2009, 03:19 PM   #3
1stToyota
1stToyota's Avatar
Mine's a '08...just curious; my cap and owner's manual states 5w30, then comes the TSB, what's the '09 oil caps and manuals say now?
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 08-19-2009, 04:18 PM   #4
DevilGirl
Drives: 09 3dr LB MT
I believe mine (09) also says 5w30. I havn't looked under the hood lately though...
Old 08-19-2009, 05:01 PM   #5
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Ditto-they still say 5w-30 on my 09 cap and in the manual. The only reference to 5w-20 I've seen is the TSB and it lists the NZ series. I keep a copy in my glove box.
-The Fitful One
Old 08-20-2009, 08:30 AM   #6
1stToyota
1stToyota's Avatar
Then Toyota isn't taking their own TSB too seriously, it seems.
2008 Scion xD
Old 08-20-2009, 08:56 AM   #7
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Well....I wouldn't go that far. It's likely that they signed up with a vendor to make the caps and they probably made up millions upon millions of these with 5w-30 screened on them.
DerFlosser is offline   Reply With Quote
Old 08-20-2009, 09:55 AM   #8
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
The second number is the SAE viscosity rating at 210 degrees F. The first one with the W after it is the viscosity at 0 degrees F. NO current oil thins out at lower temperatures or thickens at high temperatures. They all thicken in the cold and thin as they get hot. The oils with wide spreads between the two numbers just change viscosity less with changing temperatures. The great advantage of the oils that don't thicken rapidly with falling temperatures (which is what the 0W tells you) is that they circulate rapidly in the engine on startup in very cold weather, which an oil of higher cold viscosity may not do.
Old 08-20-2009, 06:55 PM   #9
Henry G.
Drives: 2008 Yaris HB
Thanks for the link, good to know. Just can't figure out either why they put the TSB out in '06 and my '08 still calls for 5w-30? I may try the 5w-20 in the winter.
Henry G. is offline   Reply With Quote
Old 08-20-2009, 07:00 PM   #10
Yaris Hilton
Smile
They didn't change their primary recommendation of 5W-30. They just said it's OK to use 5W-20 (which thins out more as it gets hot.)
5W-20 isn't any better in cold weather than 5W-30. They have the same viscosity at 0°F. The 5W-20 thins out more at 210°F than the 5W-30 does.
Old 08-21-2009, 08:00 AM   #11
1stToyota
1stToyota's Avatar
I use Pennzoil Platinum and found it odd that their 5w-20 had an ACEA rating of A1/B1, but their 5w30 is ACEA rated at A5/B5, which BTW is equal to the Amsoil High Performance 5w30 that I used to use, except the PP gets API approval.
2008 Scion xD
