Old 08-19-2009, 01:56 PM   #1
ExocetCom
ExocetCom's Avatar
Drives: 2007 Toyota Yaris RS
Re: Clutch squeak
Maybe to help identify your problem, could you determine if the squeak is coming from the engine bay or inside the cabin?
If it's inside the cabin, it's probably just a hinge for the pedal itself which you could probably shoot some lithium grease at inside the cabin. If it's inside the engine bay then maybe there's some friction on the clutch cable (I think these are cable-actuated clutch vehicles, not hydraulic). Though if the squeak is coming from insdie the bell housing, then that's probably something you can't fix without opening up the trans housing to get at the clutch spring.
ExocetCom is offline   Reply With Quote
Old 08-21-2009, 10:51 AM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Originally Posted by ExocetCom View Post
Re: Clutch squeak
If it's inside the cabin, it's probably just a hinge for the pedal itself which you could probably shoot some lithium grease at inside the cabin. ... ... ...
These are hydraulic clutch actuation. I wouldnt put petro-grease on a plastic part w/o first knowing compatibility - some lubes could soften the plastic then you'll be worse off pretty soon. If desparate, Most plastics can tolerate coconut oil and milkfat youll find around the kitchen. Dont laugh - good lubricants!
TheSilkySmooth is offline   Reply With Quote
Old 11-09-2009, 12:16 AM   #3
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Mine's been acting up over the weekend while shifting from 2nd to neutral, and again into 1st. Will run out tomorrow to get grease thanks to this thread
Old 11-19-2009, 04:00 PM   #4
abhinav_kr
Drives: Toyota Yaris
Where is this part located in this?
abhinav_kr is offline   Reply With Quote
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 04:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 11:41 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
