1stToyota meant 10 volts. If you have a multimeter, check the voltage across the terminals. You want at least 10. AutoZone near me checks/charges batteries free as a courtesy
#2 | |
Audio Junky
A 10amp charge is meant for a quick jump start. go for a 1-2amp trickle charge, its meant to give a much fuller charge. Charging batteries is like pour a glass of guiness. if you do it fast you will fill up the glass, but it won't actually be full, it'll be a wierd frothy mixture of liquid and air bubbles.... You'll get some, but its not really a full glass. You pour it extremely slow and you'll actually get more in your glass. remember, batteries use chemical reactions to produce electricity, it takes awhile to get all the chemicals set up for those reactions when re-charging. |
#3 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Any time I quick charge I remove the - battery cable...charging volts can go beyond 16v when charging is near complete. |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 02:40 PM |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 02:02 AM |
| Slow Cranking - Battery? | IGGGY | General Yaris / Vitz Discussion | 15 | 08-08-2009 11:50 AM |
| How long would my battery live with amps while the car is off? | eii | In Car Entertainment + Electronics (audio / video / alarm) | 12 | 06-15-2009 04:28 PM |
